kanks Offline
#1 Posted : Friday, 17 November 2006 9:23:54 PM(UTC)
kanks
CAN ANYONE TELL ME IF THE FRONT SUBFRAMES AR THE SAME ON HG/HK AS MINE HAS BEEN REPAIRED 2 MANY TIMES AND HAVE BEEN OFFERED A RUST FREE HK ONE.ALSO MINE IS PREM .HK IS NOT CAN THE LIGHT SUPORTS BE SWAPED OVER ANY INFO MUCH APRECEATED THANKS
#2 Posted : Friday, 17 November 2006 10:10:42 PM(UTC)
This was discussed a few days ago. A Search should turn up the thread.
I am no expert on HK/T/G's but I believe the HK is a bit different to HT/HG.
The light supports can be swapped over AFAIK.
Cheers...Dave
Fred Offline
#3 Posted : Saturday, 18 November 2006 4:18:03 AM(UTC)
Fred
Yep HK is different to the HT,HG I looked at them all when diciding
which one to install into my Plymouth rat rod project which except for the diff runs all Holden gear.
#4 Posted : Saturday, 18 November 2006 9:42:00 AM(UTC)
The HK subframe does not have the out riggers for the gearbox crossmember.
#5 Posted : Saturday, 18 November 2006 9:46:02 AM(UTC)
The light supports can be swaped but only if you can weld, to weld them back on
