#1 Posted : Monday, 20 November 2006 5:08:40 PM(UTC)
hi i have the first serires of the fuel injected 84 model ford falcon station wagon and i am wondering if it is leaded or unleaded.
Paul351xb Offline
#2 Posted : Monday, 20 November 2006 9:23:31 PM(UTC)
Paul351xb
Should be leaded. Don't think they brought out the unleaded until late 85, early 86. If the car is unleaded it should have the smaller fuel neck on it.
#3 Posted : Tuesday, 21 November 2006 12:00:01 PM(UTC)
Unleaded started on 1 Jan 1986 in Aus. As Paul said above, it should have a restrictor in the neck if it is suitable for ULP.
Assuming it IS an 84 model, you should run it on PULP or better and consider using an upper cylinder lubricant like Moreys or
#4 Posted : Tuesday, 21 November 2006 6:18:58 PM(UTC)
yeah what has been said,i run my leaded xf motor using flash lube with no probs
#5 Posted : Wednesday, 22 November 2006 6:51:11 PM(UTC)
cheers thanks very much
