#1 Posted : Friday, 24 November 2006 7:59:50 AM(UTC)
hey guys, need some info, what problems might I run into if I put hz wishbones onto a hj chassis. I have been told that the angles are different, so they won't fit. I want to use the radial tune suspension from the hz and put it on the hj.
#2 Posted : Friday, 24 November 2006 8:33:37 AM(UTC)
They are the same thing. On HZ, RTS geometry differences are in the chassis, not the removable parts. You need to change the rails, or cut off the HJ top mounts and weld the HZ ones on. There are other differences too such as springs, sway bar mounting po
