#1 Posted : Friday, 24 November 2006 6:57:04 PM(UTC)
Hey all
Just read the post a few below about lack of availability of brake proportioning valves for Hqs.
So if thety are no longer available what is the recommended fix if this becomes a problem?
Any brake gurus out there got a solution??
#2 Posted : Friday, 24 November 2006 9:09:12 PM(UTC)
Australian Brake Sleeving repair just about any brake part. Give them a call on 02 6297 6100
#3 Posted : Saturday, 25 November 2006 2:04:12 AM(UTC)
on prportioning valves for the hq sleeving is only part of the problem finding the orings and rubber seal may be better remove it put in a joiner and go for a later model with out the back brakes willlock up that type under the floor only came out on the
#4 Posted : Sunday, 26 November 2006 10:59:55 AM(UTC)
After market adjustable proportioning valves are available or you can make one yourself pretty easy.
