Holdenon Offline
#1 Posted : Monday, 7 May 2007 7:19:39 AM(UTC)
Holdenon
I bought a NOS diver side door latch from eBay some time ago. I went to fit it today as my old one was being painfull.
After removing the old one and getting it in place the HQ screws would not go in. I removed it and even out of the door they would not go in. In a brainwave I thought it could be a later model latch and hence be metric screws. Having a spare HZ/WB (not sure but not Hq) door in the shed took the screws from it - still no cigar.
Does anyone have any clue what is going on. Is there a trick or did they forget to tap out the holes with thread at the factory?
cheers,
Scott
#2 Posted : Monday, 7 May 2007 8:10:44 AM(UTC)
could still be metric you aren't sure what the one out of the garage is. look in the holes and see if they are threaded.
#3 Posted : Tuesday, 8 May 2007 5:18:59 AM(UTC)
The latches have no thread in them,before you put the latch in use your old screws to make a thread again.you will need a little force but they will go in.
Cheers...mario
