#1 Posted : Saturday, 21 August 2004 12:32:20 AM(UTC)
opinions on v6 conversions and castle auto electrics for v6 into hz s/wagon conversion kit. who is a better organisation? who would you recommend?
#2 Posted : Saturday, 21 August 2004 1:38:18 AM(UTC)
For the work and costs involved I would go 308.
#3 Posted : Saturday, 21 August 2004 1:47:57 AM(UTC)
I been thinking of this conversion myself. And think that the V6 is the way to go. They are cheap as hell, compared with around 2 grand for a V8 and gearbox set up. Plus for a Daily driver you couldnt ask for a better motor. plus there is the cheaper r
#4 Posted : Saturday, 21 August 2004 2:23:04 AM(UTC)
But remember you have to chop the subframe, there's engineers cert, run petrol lines to rear, change the emissions setup, get the electronics working, and I thinkl the conversion costs around 5 grand, naturally you can save by getting a motor and gearbox
#5 Posted : Saturday, 21 August 2004 3:06:16 AM(UTC)
John,
Why do you need to cut the sub frame?? I thought with a modified sump it would be a bolt in application??
#6 Posted : Saturday, 21 August 2004 3:51:16 AM(UTC)
to set the scene: i've got the engine and box for free. but it's the mounts, sump and g/b crossmember, speedo kit and wiring kit needed for the conversion. Both Castle Auto electrics and V6 conversions have these kits for $1365 however what i need to know
#7 Posted : Saturday, 21 August 2004 7:48:10 AM(UTC)
The changeovers I have seen they had to cut a section out of the crossmember and weld a section in. I am not sure why but I guess the sump can't succesfully be modified. Maybe it's the position of the oil pickup. Actually I think they have to modify the s
#8 Posted : Sunday, 22 August 2004 8:09:36 AM(UTC)
Daniel
The thinking behind the V6 is good. However I have to agree with the other guys, and recommend an injected 5-litre. You can pick a complete conversion up for $3000. You'll need to change the sump to a HQ-WB one, and use HQ-WB engine mounts. The ot
#9 Posted : Friday, 27 August 2004 11:55:37 PM(UTC)
John, i think your thinking of a V6 into an old holden using a HR crossmember, the rod shop cuts the crossmember in the middle and sections it at an angle down towards the rear ?
the conversion for a HZ is really simple, it only requires the engine
#10 Posted : Tuesday, 2 November 2004 6:19:28 PM(UTC)
This page was generated in 0.115 seconds.
