Mr HT gts Offline
#1 Posted : Tuesday, 8 May 2007 7:18:26 AM(UTC)
Mr HT gts
Hi all,
I have a xy 351c falcon and the battery was relocated in the boot, I have purchased a new reproduction 351 v8 battery tray from GT Ford Performance but i can't work out how to put it in, every way i try the holes don't line up down the bottom, or it hits the radiator, its driving me crazy !! where does that 'Z' bracket attach to either ??
I know it will be like explaining colors to a blind man but Any help would be appreciated,
Mal.
6pak Offline
#2 Posted : Tuesday, 8 May 2007 8:18:05 AM(UTC)
6pak
Hi Mal, Iv'e got a ZD with a Windsor so I don't know if there are some subtle differences in battery trays but here goes. The tray has a lip bent over at one end that hooks over the lowere edge of the battery casing, this goes into the recess first agai
Mr HT gts Offline
#3 Posted : Tuesday, 8 May 2007 8:31:05 AM(UTC)
Mr HT gts
6pak, thanks heaps i think you maybe right with welding up the holes, you can see slight marks on the inner side of the rail were it would normaly bolt up I think i will just have to go and find v8 falcon (i think it has to be a 351 or at least a clev bec
6pak Offline
#4 Posted : Tuesday, 8 May 2007 10:15:20 AM(UTC)
6pak
Hi Mal, I've looked at a few photo's of a GT engine bay on www.australianmusclecarsales.com.au and it would appear that there are huge differences between the battery trays of Windsors and Clevelands (please disregard my original post as it's pretty much
6pak Offline
#5 Posted : Tuesday, 8 May 2007 10:37:41 AM(UTC)
6pak
What I meant to say was "which resulted in a need to move the battery". I should probably go and get some sleep now. :)
