#1 Posted : Wednesday, 6 December 2006 2:13:00 AM(UTC)
I am pretty sure this is wrong but i thought i would ask to see if anyone has any ideas.
my xb has a 351 and a fmx auto.
when i am at stopped in drive the car idles at 1200 rpm yet when i put it in neutral it idles at 2400 - 2500 rpm. also when i put the car in gear it clunks hard and the car lurches forward.
now i would expect a gain of maybe 400 in revs but 1200 - 1300 this seems wrong.
have i got a ****ed transmission?
#2 Posted : Wednesday, 6 December 2006 4:23:31 AM(UTC)
Sounds like the idle is too high and the clunk is caused of the high idle
XB351 Offline
#3 Posted : Wednesday, 6 December 2006 5:10:27 AM(UTC)
XB351
Also sounds like your idle circuit isn't working properly hence the idle screw having to be turned up that much. Once you sort your idle circuit you'll need to adjust the mixture screws as well.
#4 Posted : Thursday, 7 December 2006 11:39:59 AM(UTC)
Thanks heaps guys did what you sugested and it worked yet the idle screw on the carby is ****ed i had to wind out the screw that sets where the eccelerator cable is. hope that makes sence,
to much to drink tonight
but anyway you wereboth right, thou
