#1 Posted : Saturday, 16 December 2006 2:47:03 AM(UTC)
will all banjo diff centres fit into hq wb houseing regardless of being coures or fine spline or torana cheers and thank you
#2 Posted : Saturday, 16 December 2006 3:06:38 AM(UTC)
Hi john.
WB series cars don't have banjo diffs, they use Salisburys. like Commodores & UCs. To answer your question all banjo centres from FX to HZ, (& LC to LX) will swap as long as you have the correct spline axles to match (FX to EJ also use a diffe
#3 Posted : Sunday, 17 December 2006 6:47:31 AM(UTC)
Just an addition, the WB & Commodore small salisbury and UC diffs use the same crownwheel and pinion as the banjo diffs. So whilst the centre is different, you can use the gears.
If we all had th
