#1 Posted : Thursday, 28 December 2006 1:58:33 AM(UTC)
G'Day,
Had this disscussion in another thread but never really solved my question. How do I ID a genuine Posi, & is it a type of salisbury diff? Is there any way to tell from the outside weather it's a 10 bolt or a 12 bolt....?
The Beige Hornet.
#2 Posted : Thursday, 28 December 2006 4:02:31 AM(UTC)
I take it that you mean an HK to HG Salisbury type differential, or do you just mean LSD. Positraction is a term used by GM for LSD and as HK to HG are the ones with US sourced LSD then these are the only true positractions used by GM-H.
With this in m
ozchevy Offline
#3 Posted : Thursday, 28 December 2006 6:57:09 AM(UTC)
ozchevy
Posi-traction diffs are a three piece housing which includes integral cast iron differential carrier and housing with pressed in and welded steel tubes.
Semi-floating forged and heat-treated axle shafts. Wheel drive flange is forged integral with the a
#4 Posted : Friday, 29 December 2006 5:42:05 AM(UTC)
So if I've got this right then 10 bolts around the rear plate is a 10 bolt & 12 bolts around the plate is a 12 bolt, but the name refers to the bolts holding on the crown wheel.
Does Salisbury just mean the style of diff with the rear cover-plate as o
FastEHHolden Offline
#5 Posted : Friday, 29 December 2006 5:49:03 AM(UTC)
FastEHHolden
My guess is that its worth a fair bit to the Monaro nuts out there..it would probably go a fair way to getting a BW78 or 9 inch with what ever brakes you want.
ozchevy Offline
#6 Posted : Friday, 29 December 2006 8:40:11 AM(UTC)
ozchevy
Yes Hornet, 10 bolts on cover equals 10 bolt crown wheel, and the same as for 12 Bolt. Salsbury is the name given to the gearing - Hypoid Differential carrier.
Don't under-estimate the durability and strength of a Posi-traction. These diffs will well and
#7 Posted : Friday, 29 December 2006 10:13:49 PM(UTC)
The only problem with the HK salisbury, as far as power is concerned, is the axle shafts are designed for 6 cylinder wheel bearings.
As ozchev said, they are dam strong, probably stronger than 9", but axles fail.
Solution is to fit 9" axles for high
#8 Posted : Saturday, 30 December 2006 2:11:44 AM(UTC)
Hi Guys.
The ID of the 9" rear axle bearings is the same as the Holden 6 & V8, at 1.378". The Ford bearing is actually about .040" narrower as well. It's the axles themselves, AFAIK they are Australian made, whereas most 9" axles are US made to suit Bi
#9 Posted : Saturday, 30 December 2006 2:14:11 AM(UTC)
Thanks guys, great advice as always. I wont need the axle upgrades just yet as I'm going back to a 186 for fuel economy reasons, but it's nice to know what it is. Was the line in Joe Dirt (?)..."God is like a posi-trac, no one knows how it works, it just
#10 Posted : Monday, 15 January 2007 1:44:43 AM(UTC)
Was under 'the hornet' today & noticed the numbers 3894859NF cast into the front of the housing on the passenger side - can anyone positivley ID the diff from this?
The Beige Hornet.
ozchevy Offline
#11 Posted : Monday, 15 January 2007 5:01:17 AM(UTC)
ozchevy
Don't know what that number is, but the one you should be looking for would be something like this as an example "GX G 112 1 E"
This is from a 1971 10 bolt posi-traction
Breaking that down would go like this,
GX = Ratio 3.08:1
G = Plant, Detroit G
#12 Posted : Tuesday, 16 January 2007 7:58:05 AM(UTC)
Where on the diff should I look for that? Old mate I got it from said it came from a Bathurst Ed HK. Doesn't look played with, I just want to be sure of what I've got.
The Beige Hornet.
#13 Posted : Tuesday, 16 January 2007 8:18:43 AM(UTC)
Just 'googled' that number & apparently that means it's a 10 bolt cast in 67 - 69. These guys were talking Camaro's, I assume holden imported the housings & put their own axles / tubes in or something...?
The Beige Hornet.
#14 Posted : Tuesday, 16 January 2007 9:22:27 PM(UTC)
More numbers if anyone can help. I've discounted the 'test' cast numbers & I'm still left with GM3 cast into the front driver's lowersection of the housing, & more ineresting is at the rear, on a flat surface next to the cover plate '742' has been stamped
#15 Posted : Thursday, 18 January 2007 8:27:36 AM(UTC)
Sorry, Cast numbers were GM63, & stamped numbers were '8742', & 'L3' upside down - c'mon, anyone got any ideas....?
The Beige Hornet.
ozchevy Offline
#16 Posted : Friday, 19 January 2007 2:21:54 AM(UTC)
ozchevy
Yes Hornet, looks like a Camaro Posi-traction -
I Googled that number as well. It would appear to be a 8.2" most likely a Eaton or GM Posi-traction from what I've just read.
#17 Posted : Friday, 19 January 2007 6:32:05 AM(UTC)
Is there any way to tell if it originated as a camaro unit or a HK Unit? I can't see any evidence of the spring saddles being moved & I was told it was from a HK Monaro (obviously I would love it to be the original HK item, but to be sure I have to be abl
#18 Posted : Friday, 19 January 2007 6:37:10 AM(UTC)
Sorry OzChevy, forgot to say 'thank you' for taking time out to google the number & come back to me - just had an epiphany, too: maybe it is a camaro unit that has had new axle tubes with the HK sadles installed. That would explain the lack of a the axle
ozchevy Offline
#19 Posted : Friday, 19 January 2007 7:35:37 AM(UTC)
ozchevy
Yes that may well be a possibility, tubes changed on an Eaton Posi-traction. Might be quite a unique differential???
Good luck with the sale of it in any case.
Guest (17)
This page was generated in 0.083 seconds.
