#1 Posted : Saturday, 30 December 2006 1:50:46 AM(UTC)
what type of sealant should i use whith the gasket and head bolt threads when i replace the heads on a 253 thanks and cheers
#2 Posted : Monday, 1 January 2007 12:28:47 AM(UTC)
You can use hylomar on the head gasket - just a light spray will do it.
And if you want to you can use holden head bolt sealer - it is pretty good
