ED57FE Offline
#1 Posted : Friday, 11 May 2007 4:14:05 AM(UTC)
ED57FE
Hi guys,
I'm trying to fabricate a high mount for my alternator and potentially an air con compressor.
I'm wondering if there are double groove water pump pulleys?
the crank pulley I know you can get double groove but the water pump??
reason i need to do this is the space is limited and no conventional mounts work.
CHeers
Ed
#2 Posted : Sunday, 13 May 2007 4:45:21 AM(UTC)
Ed,
I'm assuming you have a Holden V8. I think some of the V8 Commodores came out with a twin row water pump pulley?? Can't help with a model sorry.
There is an aftermarket bracket that bolts the aircon compressor in on top of the intake manifold in fr
ED57FE Offline
#3 Posted : Monday, 14 May 2007 6:18:48 PM(UTC)
ED57FE
Hey MAtt,
thanks for the reply.
yep its a 308, after some looking on the weekend, i figured a low mount alternaotr on drivers side (with fuel pump removed) and ahigh mount for the compressor would be the go.
currrently i have a high mount 120A al
#4 Posted : Monday, 14 May 2007 11:46:45 PM(UTC)
Ed,
If this is the case, then you have the option of using a Torana alternator bracket as these mount reasonably low on the drivers side. Its also possible to adapt the VT alternator bracket to suit a Sanden compressor fairly easily and you already have
ED57FE Offline
#5 Posted : Monday, 14 May 2007 11:54:41 PM(UTC)
ED57FE
MAtt,
thx for the heads up on the torana bracket,
trouble with a V8 into an early girl is the subframe usually interferes with the swing of the alternator.
Ed
