YetAnotherForum.NET Help
#1 Posted : Tuesday, 2 January 2007 6:22:07 AM(UTC)
hi guys just a quick question, i have a TH400 in a hj and want to know are the 2 pins sticking out the side of the box for the park/neutral switch. If not where is it. and how do i hook it all up (Legally because im going for rego). Also i have a megashifter and i noticed there are pins on that as well can i by-pass the box and use the shifter and again if so how???
any help greatly appreciated
mackv8 Offline
#2 Posted : Tuesday, 2 January 2007 7:47:14 AM(UTC)
mackv8
the neutral switch is on the factory floor shifter or if it was colum it will be on the lower part of the colum in side under the dash
looking for an ex ambulance based on the hj/x/z 2 tonner see photo
and collector of all things ambulance police fire and the odd hq to wb parts
#3 Posted : Wednesday, 3 January 2007 4:23:07 AM(UTC)
The factory shifter is long gone. its got a megashifter and no its not a column shift
Sandman Offline
#4 Posted : Wednesday, 3 January 2007 4:34:00 AM(UTC)
Sandman
The switch in the gearbox is for your kickdown. You need to wire it to a switch on the accelerator pedal.
If the car you are doing was originally an auto, just check the wiring diagram for the wires to connect to the switchs on the Megashifter. One switc
#5 Posted : Wednesday, 3 January 2007 5:39:56 AM(UTC)
Actually i dont know what it was originally, but i know it use to have a top loader in it-but thats no help, i'll get the code numbers and check that one. so now that i know what the megashifter pins are for, can i hook them up directly. if so how??? (as
This page was generated in 0.367 seconds.
