#1 Posted : Wednesday, 3 January 2007 12:20:15 AM(UTC)
HI, we have a 5ltr vs statesman that occassionally cuts out while driving and sometimes when on idle. the car just loses power. It takes around 15 - 20 minutes to start again.
we had the fuel pump changed and the igniton was loose so got that fixed.
its hard to test if its air, fuel or spark when the car is in order because the problems not there.
we had a 2 inch exhaust fitted and now the problem seems to be there, the o2 sensor has been tersted and is fine, i think the exhaust was just a coincidence.
my thoughts are the b.c.m or computer ?
has anyone else had similar problems and what did they find?
#2 Posted : Sunday, 7 January 2007 4:32:32 AM(UTC)
hi craig sounds like a pain ... did you change your fuel filter? &if so was it full of s**t ,& when you lose power do you mean the engine cuts out (stalls). does it crank over but not fire up (ignition light on).if so check for spark when engine stalls co
Rhys Offline
#3 Posted : Sunday, 7 January 2007 6:52:50 PM(UTC)
Rhys
Hi Craig, my sister had a similar problem with her VSII V8 Statesman. It was a cracked coil (apparently) - I didn't see it and have never heard of it before. They put a new coil into it and the problem went away. Also I've heard that the ignition module -
1tun Offline
#4 Posted : Sunday, 7 January 2007 9:50:45 PM(UTC)
1tun
I had the same problem so i replaced dizzy,coil and ignition module,apparantly the ignition module played up and stuffed the dizzy.Dont buy a reco ignition module as the 1st one i got was no good and others i know have had probs with them.
