neil Offline
#1 Posted : Thursday, 4 January 2007 2:54:25 AM(UTC)
neil
does running a holley 850 DP in a unworked 351 give any advantage or disadvantage
#2 Posted : Thursday, 4 January 2007 4:32:29 AM(UTC)
My experience prefers a smaller carby doing more work than a larger one. The faster air stream through the venturis on a smaller carb mixes fuel better. I was a crew member on NASCAR in australia and they run a 600 on a 350 chev. And they go fairly hard
#3 Posted : Thursday, 4 January 2007 10:51:35 AM(UTC)
A 850 DP is too big for a stock 351 you should use a 600 vac as it works the best
landy351 Offline
#4 Posted : Thursday, 4 January 2007 6:37:52 PM(UTC)
landy351
I have found with my stock 351 4V that the best performance and fuel economy that I have ever had was throw the holley in favor of a carter 625cfm AFB carby.
regards Landy351
