#1 Posted : Friday, 11 May 2007 8:49:29 PM(UTC)
Hi all,
New to this site. Have posted these two issues on other sites with limited success so thought I would try here. Just bought a 2003 VY Commodore Station Wagon and now noticed that it has a loud hissing/fan belt noise from the fanbelt/pulleys. Is this normal and if not what could it be. Has been sprayed with WD40 and Beltgrip with No success. Holden dealer seems to think one of the pulleys. Does this sound right. Also yesterday was absolutely pissing down and noticed the two ends of the rear seat were wet. Would appear that the top of the door seals have leaked. Is this normal and do VYs suffer from this or is it a matter of having an expert look at it. Have had some mixed thoughts at work and one bloke said that the VY's were renowned for door leaks. Help needed before taking vehicle to the expensive Dealer.
regards
Brad
Sandman Offline
#2 Posted : Sunday, 13 May 2007 8:35:13 PM(UTC)
Sandman
Have you checked the idler pulley?
If the bearing in that is seizing up, which they can do, that could be the cause of your problem. Take the belt off and turn it by hand and feel for any roughness etc.
Also while you have the belt off, I'd replace it
Rock_Lobster Offline
#3 Posted : Monday, 14 May 2007 1:25:50 AM(UTC)
Rock_Lobster
I have a VY (series 1) SS Wagon. No problems with leaking windows.
I did have rattling door lock knobs. The foam had worn off the back of them. New set fixed this. I currently have torn window seal material on the LH rear, at the pillar. This is to be fi
xd 351 Offline
#4 Posted : Friday, 18 May 2007 9:29:57 AM(UTC)
xd 351
my vy series 2 ss ute dont leak either
only milk and juice comes in 2 ltr
