#1 Posted : Sunday, 7 January 2007 12:31:25 AM(UTC)
Hi could anyone tell me where i can get adjustable rear 4 link torsion bars for my LX torana. Do i have to get them custom made?
Thanks for any help
#2 Posted : Sunday, 7 January 2007 12:44:11 AM(UTC)
SORRY MATE CANT HELP ILL ASK SOME FREINDS
ozchevy Offline
#3 Posted : Monday, 8 January 2007 11:41:42 AM(UTC)
ozchevy
If your thinking of setting up a 4 link, then your in for a huge modification. You will need to build a frame to house the linkage out of 3"x 2" RHS to weld into your chassis rails. You will also need to cut out the floor around your back seat and re-fabr
Mr Void Offline
#4 Posted : Monday, 8 January 2007 9:25:18 PM(UTC)
Mr Void
I'm considering using one of these 2-link kits on the tonner, they don't cost an arm or a leg BUT I don't know what complimentary mods you would need to fit it up to the LX?
http://www.mcdonaldbrosr...ng.com.au/2linkkits.html
___________________
___________________
BrianH Offline
#5 Posted : Monday, 8 January 2007 10:43:38 PM(UTC)
BrianH
Randy
What do you want to do with this car? If its use will be predominently street,and a good ride and handling is important, then you will most likely be better off with what you currently have. There is always some degree of binding in four link s
#6 Posted : Tuesday, 9 January 2007 2:56:02 AM(UTC)
The main problem is the diff is not running straight. I dont no what has caused this but it looks like a mount has been ripped out before. maybe the 9 inch wasnt done right i dont know. i thought if i could get some lower adjustable arms i could line it u
