#1 Posted : Friday, 12 January 2007 10:09:45 PM(UTC)
have HK 307 with overheating problem. temp is fine when driving but overheats when idling for a few minutes. have engine driven fan, have put in reco 4 core radiator, new water pump, therostat & radiator hoses, flushed motor, installed over flow bottle. any ideas ?
bluHJ Offline
#2 Posted : Saturday, 13 January 2007 2:10:29 AM(UTC)
bluHJ
Is it physically getting hot or just recording it as hot? A friend of mine had problems with his centura many years ago. Did the same as you but it turned out to be a faulty temperature sender. He replaced that and had no further problems.
bluHJ
#3 Posted : Saturday, 13 January 2007 2:21:09 AM(UTC)
Do you have a strap from the -ve battery terminal to the body, not just to the engine?
#4 Posted : Saturday, 13 January 2007 11:45:22 PM(UTC)
car is definately getting extremely hot, has negative strap from battery to body. just put in 71 degree C thermostat, thermo fan & reset timing but still runing hot as.
#5 Posted : Sunday, 14 January 2007 2:30:33 AM(UTC)
Does it have a shroud around the fan?
#6 Posted : Sunday, 14 January 2007 7:39:50 AM(UTC)
yes has fan shroud
