#1 Posted : Wednesday, 17 January 2007 9:06:57 AM(UTC)
My statesman a/c does this weird thing sometimes , I have it blowing on face mode only and it works well then for no reason it will change to blowing inside the dash , the fan is still blowing but nothing comes out the vents ! eventually it goes back to normal.
Is this a VS thing ? common problem? It has only started doing it recently.
#2 Posted : Wednesday, 17 January 2007 9:54:45 AM(UTC)
I have fitted a few clips on to the little rods that open and close the vents on those model cars and Coventrys said they sell lots of those clips.Have a look for that.
jabba Offline
#3 Posted : Wednesday, 17 January 2007 3:39:14 PM(UTC)
jabba
Also check the vacuum selector, as they can play silly beggars. The dial in the dash works by feeding engine vacuum to different pipes to activate the various blowy directions. If the engine vacuum disappears, or the selector is stuffed, then it will no
