#1 Posted : Sunday, 28 January 2007 7:43:29 AM(UTC)
You have been a member since:: 2/09/2015(UTC)
hey there all,
need help we just bought a ford xc ute rally pac.
now it has a 351c engine in it.
now it has the engine number stamped on it on the front just above the waterpump.
it has an X stamped there then engine number below jte55582y we were told its a xygtho block is that true??
we also got a pair of 4v heads casting number doae oc 23 are these heads anygood??
anyhelp would be great as we are very confused by what engine we have and is the xc a gs rally pac and what it would be worth.
thanks
Paul351xb Offline
#2 Posted : Sunday, 28 January 2007 9:20:11 AM(UTC)
Paul351xb
XY GTHO block should start off JG33. What you have listed makes no sense to me unless the block has been restamped by someone like the police. Is the ute registered?
Munromad2004 Offline
#3 Posted : Sunday, 28 January 2007 9:24:42 AM(UTC)
Munromad2004
All Falcon GT's will have an engine number beginning with JG33 or JG66 (coupes). Apparently a JH prefix also exists for GT's.
I think you are looking at a casting number and not the engine number.
#4 Posted : Sunday, 28 January 2007 9:33:24 AM(UTC)
where will i find the engine number then.
what is says on the body is t for the engine but for had fitted a 428 cobra jet engine in it.
then it was replaced with a 351c engine.
yes the ute is registered.
i just want to find out as this is the first fo
#5 Posted : Sunday, 28 January 2007 9:46:09 AM(UTC)
if i take some pics of the heads and engine is there anyone that could tell me that way??
Paul351xb Offline
#6 Posted : Sunday, 28 January 2007 9:56:58 AM(UTC)
Paul351xb
What does it say on the rego sticker? Engine number should be on the rego sticker. ( is in QLD ) Clevo engine number should be on the passengers side, below the head at the front. poke around with a torch, you should see it as long as it hasn't been gro
Paul351xb Offline
#7 Posted : Sunday, 28 January 2007 10:10:14 AM(UTC)
Paul351xb
With the compliance plate your ute was a falcon 500 utility with a 351 originally. So should have the nine inch diff out back too. More than likely with the 351 the car was a Factory GS. Car would have had sports dash, GS grill with the driving lights,
#8 Posted : Sunday, 28 January 2007 7:28:17 PM(UTC)
hey there,
yes it does have all those features and it has either a top loader or a single rail in it.
car has vic rego. we paid $4000 for it motor has just under 400hp runs very well we are looking for 3.5 gears for the nine inch as it has 2.7 gears i t
#9 Posted : Sunday, 28 January 2007 11:13:36 PM(UTC)
hey there just looked on the rego and the engine number starts with jg23 on the sticker.
now on the id tag it says falcon van
so makes it more confusing to what it actually is?
#10 Posted : Monday, 29 January 2007 4:41:16 AM(UTC)
Munromad2004
If the engine says JG23 it is out of a Falcon 500 sedan.
Definitely not a GT motor.
I wouldn't be too concerned with the tag saying Falcon Van. Things like that do occur. Falcon coupes actually have Falcon Sedan stamped on their ID plates.
#11 Posted : Monday, 29 January 2007 5:51:53 AM(UTC)
well thats what the rego stickers says but the engine number on the block is different so which one do i use??
engine number off block is jte55582y and has a square thing on the front of motor just above waterpump like the old d block
#12 Posted : Monday, 29 January 2007 7:31:00 AM(UTC)
Munromad2004
Where are you getting this jte engine number from? Is it on the LH side of the engine block on the flat surface just near where the head bolts on?
You really need to show us a photo of this block and in particular this engine number.
If the engine
#13 Posted : Monday, 29 January 2007 7:40:38 AM(UTC)
hey there,
that number is located just above the fuel pump and its the engine number which is on the transfer papers i looked at the back of the engine passenger side there is some numbers from what i can feel just cant get in there to look.
i was tol
Paul351xb Offline
#14 Posted : Monday, 29 January 2007 11:25:26 AM(UTC)
Paul351xb
Square block is the aussie cleveland block. Came out in about late 72 I think. Did you read the link I posted here for you? There is more info if you click on next page at the bottom. As munromad says, send us a few pics of the engine. Put the pics o
#15 Posted : Monday, 29 January 2007 11:16:08 PM(UTC)
Munromad2004
Ok, it's starting to make a bit on sense. The engine number is on the left hand front side of the block (not the rear)
Unless it is a JG33 engine it is not a GTHO block.
Other than that, you've got us stumped.
