#1 Posted : Thursday, 1 February 2007 5:29:11 AM(UTC)
Hi guys,
I recently just swapped my old 308 engine from the hz tonner with a s/h engine (approx 10 months from its last start) and have noticed when I started it it has a loud knocking sound from the bottom of the engine. The engine was supposed to be in good condition with no knocking sounds.
Before starting it, I put new oil and oil filter and let the engine rotate for a little while before actually firing it up. Im hoping its making the knocking sound because the oil needs to still go through the engine and not a crank problem.
Any suggestions or advice would be greatly appreciated.
THanks in advance
Frank
Edited by user Thursday, 1 February 2007 5:33:33 AM(UTC)  | Reason: Not specified
ozchevy Offline
#2 Posted : Thursday, 1 February 2007 5:45:34 AM(UTC)
ozchevy
Hi Frank,
I would have probably not filled the sump with oil straight away, just circulate a mix of diesel and clean oil in there firstly for a couple of minutes running. This will clean up all the oil galleries and flush out all the nasties. Once this i
#3 Posted : Thursday, 1 February 2007 7:09:45 AM(UTC)
Thnx for the advice, I will take the oil out and try your method to clean it out a bit. Would half a litre of diesel and half litre petrol be ok?
Also did you mean take the sump off and put it in there or can i put the mixture straight into the oil fill
edmundo Offline
#4 Posted : Thursday, 1 February 2007 7:20:16 AM(UTC)
edmundo
You may even "prime" the oil pump. Take it off, and fill with oil, then put it back on. I had the same prob., Was running very noisy on the first start.
ozchevy Offline
#5 Posted : Thursday, 1 February 2007 8:08:37 AM(UTC)
ozchevy
No need to remove the sump, just a 50/50 mix oil and diesel straight into the filler, and drain out through the sump plug.
#6 Posted : Tuesday, 6 February 2007 3:30:37 AM(UTC)
Connect a remote accurate oil pressure gauge before you start it again. Pressure should come up fairly quick. Priming the oil pump would also be a good move.
#7 Posted : Tuesday, 6 February 2007 5:54:38 AM(UTC)
Thanks for all ur help guys, cleaned it out with the diesel and it sounded better than before. Just now it seems like there is no oil pressure as i can hear the noise from inside the rocker covers which could indicate the oil isnt getting up there.
Im g
