Vintage Caravans Offline
#1 Posted : Friday, 2 February 2007 4:14:47 AM(UTC)
Vintage Caravans
Hi All,
I have a 79 F100 (351) and was wanting to change from Manual to Auto, and have a few questions,
1. What gearbox did they come out with?
2. is there a better gearbox to convert it to?
3. is T-Bar ot Column auto easier to set up?
Vehicle is RWD and it is mainly used as a daily driver, with the odd towing duties for car and trailer, also used on yearly trips away. Any help would be greatly appreciated
Matt
79 F100 XLT 351, 60 Bedford TJ3 308 and 62 EK 283 Wagon Project, it is more than a hobby it is an obsession!!!
1962 EK Wagon - Chev SBC & T700, 1962 EK Sedan - Chev SBC & T700,EK Ute - V6 Buick & 5 speed = LOOKING FOR A 1962 EK VAN
#2 Posted : Tuesday, 6 February 2007 5:31:12 AM(UTC)
get a c10 auto and a floor mount shifter thats the easiest b&m make a truck shifter thats pretty good
i had a 82f100 that was a 6 swapped over to v8 cleveland and c10auto but mine already had all the auto linkage setup on it so unless you want to buy al
Dmax Offline
#3 Posted : Tuesday, 6 February 2007 8:09:18 AM(UTC)
Dmax
I think they came out with either the c4 or FMX. The fmx is a heavy box but reasonable robust. The C4 is a good average auto box but is easily tricked up to a super tough box which is used in many drag cars. As Keogh said, the C10 is a good box but you
Edited by user Tuesday, 6 February 2007 8:11:00 AM(UTC)  | Reason: Not specified
648hp Tunnel Rammed 351, It does not get any better
#4 Posted : Saturday, 10 February 2007 4:20:24 AM(UTC)
Vintage Caravans
Thanks guys, what is the differences between the C4 and C6 and C10????
I have been looking and found the C10 is pretty expensive, compared to the other two??
Matt
Dmax Offline
#5 Posted : Saturday, 10 February 2007 10:53:18 AM(UTC)
Dmax
I think they just get tougher, not sure about ratios, they maybe different as well.
Paul351xb Offline
#6 Posted : Saturday, 10 February 2007 10:47:00 PM(UTC)
Paul351xb
I can tell you the C6 for the cleveland is a heavy moungrel. Much heavier than the FMX which in turn is heavier than the C4.
#7 Posted : Sunday, 11 February 2007 6:39:01 AM(UTC)
Vintage Caravans
ah OK then,
so do you think the C4 would handle the job of towing in the F100, as I can get a cheapish one, and get it rebuilt, is there anything I should be getting done to it when it is freshened up??
Matt
Effie351 Offline
#8 Posted : Monday, 5 March 2007 8:36:08 AM(UTC)
Effie351
G'day Matt
I have a SWB 4X2 79F100 it came stock with a 351C/C6/3.5:1 9 inch LSD.
Its a pretty tough drive line.
Mines a coloum shift but if I was doing a conversion I think I would just go the floor shifter.
Hope this helps
Mike
