i have a 308 that has the enging number starting with QT I am trying to find out wot it was fitted to so i can work out what the gearbox patten is the other thing is can any one help with regards to fitting injection to it as its on a carby now,
QT is anything from HQ to late HZ with any box from a trimatic, m21, Th350 or TH400. Built in both trimatic and turbo bolt patterns. I may be able to tell a bit more from the numbers after QT. As for injection off a VN/VP it's fairly easy. But it invol Edited by user Sunday, 18 February 2007 7:01:44 PM(UTC)
| Reason: Not specified |
thanks for the help byron iv sent the details to your email .regards jac
