#1 Posted : Sunday, 27 May 2007 4:39:58 PM(UTC)
Hi People,
Can anyone tell me if I was to use a proportioning valve from a Corvette on a HQ would it work? The reason for my question is Corvettes use 4 spot where HQ has only 2 spot. This is for a rear disk conversion. I have been told it doesn't matter.
Thanks.
Matt
HZute-efi-VS5L Offline
#2 Posted : Thursday, 31 May 2007 8:28:28 AM(UTC)
HZute-efi-VS5L
cant use a disc rear valve on drum rear brakes. not to sure if that answers your Q. also the weight and balance of the car would be diff to hq and corvette. even in say a HZ Ute and a HZ sedan both running disc front and drum rears i believe the prop v
www.stickthisdecals.com.au
