RussVRute Offline
#1 Posted : Friday, 23 February 2007 8:33:44 AM(UTC)
RussVRute
G'day all,
I need to change the aerial on the ute, thanks to forgetting to put it down when I went through the carwash...DOH!!! Anyway, it has a manual aerial at the moment, what I need to know is, did all VR's come out with power aerials as an option? remembering that the ute is a very base model, no bells or whistles to speak of. The reason I ask is, before I go and spend the cash, I wanna know if there is likely to be wiring there somewhere to plug a power aerial into, or will I need to run all new wiring. Any help appreciated. Russ.
#2 Posted : Friday, 23 February 2007 6:43:15 PM(UTC)
As far as installation of the antenna goes. you need to remove the inner splash guard (plastic liner) & fit the aerial in - the electric one has a bracket that bolts thru the inner pillar just above & in front of the PCM (engine computer) accessible behin
RussVRute Offline
#3 Posted : Saturday, 24 February 2007 10:09:26 AM(UTC)
RussVRute
Thanks Mick, that was fantastic info, now I know exactly what to look for on the weekend when I pull it apart to check things out.Cheers.Russ.
