#1 Posted : Sunday, 25 February 2007 8:41:10 AM(UTC)
what will happen if i fit a master cyl to suit disc front and disc rear to a hz ute with disc front but drum rear? as the master will not have the valve in the drum rear port. will this maybe be an issue u think?
what about a dual diafram booster? will this also cause problems if i fit one to my ute with drum rears.
i am going to do disc rear soon but yeh gota find the time to set it up =)
jason
stopgo Offline
#2 Posted : Sunday, 25 February 2007 11:14:01 PM(UTC)
stopgo
It will work
#3 Posted : Monday, 26 February 2007 7:52:55 AM(UTC)
even tho the drum valve isnt installed? will it upset the drum brakes?
cheers!
mackv8 Offline
#4 Posted : Tuesday, 27 February 2007 1:57:27 AM(UTC)
mackv8
you need the valve in to hold line presser or the wheel cyl,s will fail (cups will collaps)
looking for an ex ambulance based on the hj/x/z 2 tonner see photo
and collector of all things ambulance police fire and the odd hq to wb parts
#5 Posted : Tuesday, 27 February 2007 8:45:01 AM(UTC)
yeh thats what i wondered. ah ill just convert to rear disc now then =)
#6 Posted : Saturday, 3 March 2007 7:49:48 PM(UTC)
I have read on this site before that if you fit the rear calipers on that the hand brake mech hits the springs.I ran a disc rear set up on my ute for three years and never had a problem with this but I got it from off the back of a van so I do not know if
#7 Posted : Sunday, 4 March 2007 5:16:57 AM(UTC)
yeh not an issue with me as im fitting VP rears onto the sals axle.
jason
Guest (5)
