3 Pages<123
Sandman Offline
#41 Posted : Sunday, 9 September 2007 2:52:17 AM(UTC)
Sandman
only know of 2. 10 bolt diffs. 1.HK-T-G. the 2ED HQ on. the one tonne has thicker axles. 10 bolt are rated at 4000 ft/lb. DANA 44 is 4400 ft/lb. DANA 60 at 7000 ft/lb. the bango is rubbish, it is a 8 bolt in a salisbury form, with fine spline axles.
Wh
#42 Posted : Sunday, 9 September 2007 4:11:04 AM(UTC)
Fallingbear the most simple way I know of is to check the oil condition for bits of metal like this
Beyond that check in the housing for the same and check for worn and damage
basketcasebear Offline
#43 Posted : Sunday, 9 September 2007 4:30:17 AM(UTC)
basketcasebear
thanks hq SS,
I will keep this in mind, I am still not sure which axle, with which diff centre I will get,
but 9inch is a tadd expensive,, that leaves 3.08 10 bolter, but i am not sure whether they are salsbury or borg warner? or which car i should be
DOH!!!
adam PERTH Offline
#44 Posted : Sunday, 9 September 2007 5:40:41 AM(UTC)
adam PERTH
Falling bear,
seriously, go the VN VP commodore (3.08 ratio)
it will be about $50 to buy.
a 3.08 10 bolt sailsbury will be minimum $400.
the commodore are stronger, have disk brakes STD.
adam.
A1 Bogan.
#45 Posted : Sunday, 9 September 2007 6:11:49 AM(UTC)
basketcasebear
thanks adam,
will look for one, got quoted a bit more for one though?
once i have put it in, i can always strenghen it later if i have probs.
but being an old bugger now, i just potter around, so it should be fine and dandy?
ptpro
DOH!!!
adam PERTH Offline
#46 Posted : Sunday, 9 September 2007 7:55:31 AM(UTC)
adam PERTH
for $50 - $100
you will have to pull it out yourself with you own tools,
suggest it over the phone when you inquire...
A1 Bogan.
Handgunner Offline
#47 Posted : Tuesday, 11 September 2007 5:47:52 AM(UTC)
Handgunner
Hi all, just hopping on board here, i too have been after a suitable diff for my HG Panno 307 turbo 400 , and have found a VN LSD to use..checking the ratio tommorow, so hopefully its a 3.08 ...$150.00 is that ok? Seems ok, nice bloke at the local wrecker
Bang Bang
#48 Posted : Tuesday, 11 September 2007 6:31:18 AM(UTC)
basketcasebear
hey handgunner,
i got quoted $120 for a non lsd today, $500 for a lsd,, is the lsd worth the diff,?? pun intendeded,
good question re booster? cause i got drum brakes on mine? but i presume it will be the same, but i am not an eggspert,
anyone on here
DOH!!!
#49 Posted : Tuesday, 11 September 2007 7:58:17 PM(UTC)
Handgunner Offline
#50 Posted : Wednesday, 12 September 2007 3:46:18 AM(UTC)
Handgunner
Missed that bargain.....!!!!!!
Hah, went to the wreckers tonight to pick up my VN 308 diff, only to find that it has been apparently sold the very next morning ! By the guy who said i can have it for $150.00 !
Hmmmm, is he reading these posts...? Do
Bang Bang
#51 Posted : Wednesday, 12 September 2007 6:07:57 AM(UTC)
basketcasebear
BUGGER!!!!! GUNNER.....
thanks jim, will see if I have a residual line pressure doobi lacky, whatsyamacallit on my rear brake booster line.?? bound to have one?
is that for drum brakes only? and disk brakes dont have them?
lots involved in this stuf
DOH!!!
adam PERTH Offline
#52 Posted : Wednesday, 12 September 2007 6:42:30 AM(UTC)
adam PERTH
Handgunner,
they are 1/4 inch shorter than HQ on either side (1/2 inch total)
not sure if HG = HQ.
i would have thought HG narrower.
You can buy the LSD centres for BW brand new still.
You have to put a small pressure reducing valve spring into the m
#53 Posted : Wednesday, 12 September 2007 7:34:44 AM(UTC)
basketcasebear
hey adam,
is the LSD diff betterer, and why? is it stronger? or just better traction?
ptpro
DOH!!!
#54 Posted : Wednesday, 12 September 2007 11:15:57 AM(UTC)
The only other thing to check if you are buying second hand is that the axles are not bent. I have seen heaps more bent commodore axles than I have on any other model Holdens. The lsds on these are just the old cone type the same as in the early Holdens t
#55 Posted : Thursday, 13 September 2007 1:34:45 AM(UTC)
sandman i am quoting page 63 of australian muscle car.
#56 Posted : Thursday, 24 January 2008 9:44:07 AM(UTC)
Looking for LSD centre 10 bolt Sulsbury
#57 Posted : Saturday, 26 January 2008 7:17:34 AM(UTC)
To add to this story- i have a canadian 10 bolt under the monaro which i had recoed back in 2000. It was noisy and i thought why not give it a freshen up as i wanted to keep the stock 3:36 LSD. Anyway it ended up costing $800 to be fully reconditioned! Af
3 Pages<123
This page was generated in 0.108 seconds.
