#1 Posted : Sunday, 4 March 2007 2:23:11 AM(UTC)
Looking for a fuel pump for 327 and was told they are NLA for 327s, Can anyone have confirmation on this, it is for a 65 Impala.
Would be interested in finding the right part for this car.
Warren
#2 Posted : Sunday, 4 March 2007 3:38:45 AM(UTC)
With a search of au.altavista.com .This is from a shop on ebay CHEV SB 283 307 327 350 400 NEW FM/CARTER FUEL PUMP au $37.95. I do not no if it is right for your car.www.americanautos.com.au list a 14-350 FUEL PUMP 283-307-327 CHEV 5/16" $35.50
Edited by user Sunday, 4 March 2007 4:07:32 AM(UTC)  | Reason: Not specified
#3 Posted : Sunday, 4 March 2007 8:06:43 AM(UTC)
My mate will contact them on Monday, thank.
Warren
edelbrock1 Offline
#4 Posted : Sunday, 4 March 2007 9:11:54 AM(UTC)
edelbrock1
Warren, you looking for the original AC embossed fuel pump, or just one that looks the same?? If it is the AC one your looking for, do you know the part number???
#5 Posted : Sunday, 4 March 2007 5:08:30 PM(UTC)
My mate is just after a pump, not worried about the AC embossed. He was told he could only get a 350 pump, with larger fuel line.
Are you after one with AC on it?
Warren
Chevman6652 Offline
#6 Posted : Sunday, 4 March 2007 8:20:35 PM(UTC)
Chevman6652
Warren a couple of suggestions, I have 66 Impala, with a 327, a few yrs back i brought a fuel pump from James from eagle performance/usa imports, Hoxton park rd. The other things that could be done is 1. if he still has the pump and it's an early pump you
#7 Posted : Sunday, 4 March 2007 11:47:55 PM(UTC)
We shall try to get one with the right outlet on it, if not there are two options as we see it.
1) Make an adaptor for 350 fuel line to 327 fuel line.
2) Strip 350 fuel pump and then repair 327 as suggested
3) put a quadrajet on and use 350 fuel line
Sandman Offline
#8 Posted : Monday, 5 March 2007 7:00:45 AM(UTC)
Sandman
Use one of the pumps HQSS recommends. If it has a larger inlet, it will still only be 3/8"on the suction. Just put some 3/8"hose on and connect it to youyr 5/16"suction fuel line. Put 2 hose clamps on the fuel line end and it won't leak. I've done it heap
