#1 Posted : Thursday, 31 May 2007 1:21:21 PM(UTC)
I cant see where the front windscreen washers bolt/screw onto, i also cant see any holes for the screws on the windscreen scuttle panel for them to fix to, although that panel looks like its been replaced,
when fitting new clips for the front windscreen chrome. which way round do they go?
any ideas
#2 Posted : Thursday, 31 May 2007 4:08:07 PM(UTC)
the grille cover is held on by phillips head screws, you will have to remove one of the wiperarms to remove it also, the washers are held in by one screw each, you will see them once the grille is removed.
hz dude Offline
#3 Posted : Monday, 4 June 2007 10:13:27 AM(UTC)
hz dude
on the clip thing from the best of my knowage
they go on in an anti-clockwise direction. the clip goes on and then push left from the front of the car on the top row and push right from the bottom .hope that helps
