#1 Posted : Friday, 1 June 2007 12:44:29 AM(UTC)
My 2003 BA XT has started consuming too much fuel. Ford service advised me the issue is with the fuel pump & the injectors. They have asked me to get the entire tank cleaned & all the fuel lines flushed. Then get the fuel pump & injectors cleaned. I have so far replaced the fuel & air filter & also cleaned the injectors. Although the problem still resides as XT is still giving me around 160Ks for 30lts. I am not really sure if I should still go for rest of the above recommended by ford which will easily set me back by atleast $2000. My next option is to get it dual-fuel retrofitted. But I haven't seen many BA's (cabs)with dual-fuel or gas. Does anyone know will this firstly solve the problem I am having with mileage & secondly if there are any known issues with this conversion. My XT has already done 150,000Ks.
#2 Posted : Friday, 1 June 2007 1:06:51 AM(UTC)
I would take it to a good dyno tune place & tell them about the problem. They may just know the common causes of this problem.
It could be something as simple as a failed oxygen sensor.
This page was generated in 0.184 seconds.
