hg_lover Offline
#1 Posted : Wednesday, 7 March 2007 10:10:37 PM(UTC)
hg_lover
I was set on a 10 bolt diff but I've found a HK 9 inch fully rebuilt with disc brakes, 3.5:1 centre etc for a good price. I have a HG ute. I'm not sure if this 9 inch was built for a sedan or ute.
My question is did the HK sedan have leafs on the back or trailing arm setup? Will the diff go in with my leafs regardless?
#2 Posted : Wednesday, 7 March 2007 10:29:46 PM(UTC)
HK are all the same. As far as the diff is concerned HK-HG are the same setup. The only thing that changes is the leaf springs are different for HT and HG as they have a bigger front bush, although HT/G manual 307/308 and 350 continued with the HK front b
Edited by user Wednesday, 7 March 2007 10:33:20 PM(UTC)  | Reason: Not specified
#3 Posted : Wednesday, 7 March 2007 10:38:53 PM(UTC)
HI hg_lover.
All HK/T/G use the ame basic leaf spring set-up, all the rear axle housing will interchange, except for the location of the flexible rear brake hose.
Dr Terry.
hg_lover Offline
#4 Posted : Wednesday, 7 March 2007 10:59:46 PM(UTC)
hg_lover
If I can't get the tailshaft, handbrake cables and mounting hardware it's not too big a deal? Not enough to justify passing it up?
I'm assuming as the add says it's set up for a HK it should have Hk/t/g discs. Hopefully talk to the guy today about the
#5 Posted : Thursday, 8 March 2007 7:05:54 AM(UTC)
Common conversion from my (very limited0 experience was to keep the ford discs & have them re-drilled or just run ford pattern on the back.
The Beige Hornet.
This page was generated in 0.173 seconds.
