What's the best fuel to use in a 308 with a mild cam? And what's the best lead replacement additive?
Hi Timbo,
The best fuel to use depends more on your compression ratio, ignition timing and the amount of carbon inside the cylinders than it does on what cam you have in the car.
Generally, PULP (95/96 Octane) or better will give you the best result
I pretty much agree with Qute on this one. One extra point, though... if you do decide to use an additive, then buy it in 1L containers (or larger) from automotive outlets, don't buy it in those little squirt bottles from servos. You'll save heaps.
P
Thanks: 1 times Was thanked: 638 time(s) in 599 post(s)
Agree with Qute on the carbon issue. I run LPG on a stock HZ 308 (9.7:1). Was recently pinging it's head off. I 1/4 filled the flashlube bottle with metho (mixed with upper cylinder lubricant), upped the amount that goes in and give it a hard run up the e |
Bryon, try switching the washer bottle outlet to the intake manifold, so you can give it a squirt by pushing the windscreen wiper button. :-)
Jason.
That's sort of what i'm thinking. But I was thinking of automating it a bit by using a MAP sensor, TPS and rev sensor so that it only works at mid-high throttle openings, reasonable revs and moderate vaccumm ie when the engine is working hard. That's when |
The reason I ask is because whether I use regular unleaded (91) or premium (98) I seem to get the same mileage out of a tank, if anything I get a bit less on the premium.
As for the lubricant, I bought the motor about a year ago with only a few thousan
As a general rule, it shouldn't be necessary to decoke (to use an old term) a motor after only 15,000 k's. For it to be necessary after such a short time would indicate that something was seriously wrong.
Are you adjusting your timing when swapping bet
Nah, not adjusting the timing. I'll have to give that a go. I tell ya what, I'd love to have one of you blokes living next door, but you'd need to build a new shed to store all the cartons of beer I'd owe ya.
Agree with Qute agin. I want to have it there permanently so I can run a little more timing available for dual fuel and not ping on LPG whilst towing or carrying a load.
_______________________________________________________ If we all had the same (g |
Higher octane fuels are more stable under high pressure and heat, so may enable you to run more advance and compression. If you are already achieving max performance with a given octane then increasing the octane will not increase mileage or performance.
Timbo, where are you? One of us just might be next door to you...
Cheers...Dave
Haha Qute, actually at the moment I'm living in my panno, so I could go and live next door to anyone. On the northern beaches in Sydney.
As mentioned, octane isn't (directly) power, just a measure of resistance to detonation. So a higher octane lets you tune more aggressively than a lower. Having said that, even different brands of fuel can give different results for the same octane. I |
__________________________________________ Keep the shiny side up, and the greasy side down. |
