wimjack Offline
#1 Posted : Wednesday, 6 June 2007 10:39:58 PM(UTC)
wimjack
I have got a set of 4v extractors and was wandering if they Will bolt up to 2v Heads?
Cheers Jack
#2 Posted : Tuesday, 12 June 2007 8:24:18 PM(UTC)
G'day,yep,they should bolt straight up.I am running a set of 4V pacemaker 4 into 1 extracters on my 2V heads.It just means the transistion from head port too extracter flange is pretty big(not that great for flow).I have modifyed my exhaust port and fitte
#3 Posted : Wednesday, 18 July 2007 12:47:18 AM(UTC)
Hi, it should be ok, even with the port mismatch.
The gas will be flowing from a small port into a bigger port, the step may in fact prevent some gas reversion back into the cylinder as the pressure waves move back up the pipe.
It's a little simila
