just bought a car alarm to fit to a HZ i'm building. just wondering if anyone has fitted one and can tell me which wires i should be joining the alarm to. i've got the gregory's wiring diagram and been working through it but would like to confirm which wires are best to join to. the car is still many months away from hitting the road and would like to sort out the wiring while there is nothing in the interior. its not easy to test while hooking it up so would like to be reasonably confident of the wiring when the time finally comes. if anyone has any ideas it would be greatly appreciated. i've got a wiring diagram of the alarm but haven't been able to attach it. it inludes wires for the indicators, door light, ignition, coil and numerous others. if anyone has some idea you can email me at [email protected] and i can send the diagram.
You are a member of these groups:: Guests
I think the best place for the alarm module is high up under the dash to where the intermitant wiper relay mounts-out of sight and away from moisture,dust etc etc and close to the fuse box. It might be easy for theives to access there but at least you can
If you can move the ignition coil to in side the vehicle would be a start. No matter what type of alarm is on it, you only need 1 wire to get the engine started that is unless it has a Electronic Ignition system.
Is it manual or Auto?
You can al
