#1 Posted : Sunday, 10 June 2007 1:03:37 AM(UTC)
Hi I have got 2 2bbl red motor manifolds. One is cast 743446-P with 114 under that. I believe this is for a HKTG 186S. The other is similar in appearance but cast 743446 4-1. Would the second one be for a HR 186S?
The only differences are some of the casting marks, but also the 4-1 manifold doesn't have the return spring bosses drilled or tapped.
Does anyone know why this is? I notice there are 2 different part numbers in the HK parts manual for auto and manual. What are the differences?
I want to use one of these for a HG 186S Auto - I assume the one with the tapped bosses (743446-P) would be the one to go with?
Cheers, Brian
wals186s Offline
#2 Posted : Monday, 11 June 2007 3:42:03 AM(UTC)
wals186s
Hi Brian, the very early HR186S inlet manifold is the one that has the cast mark where they were going to cast the boss later on for the HK-G range.
The second type HR on is the one that has the boss cast on the rear runner, but thay are not drilled o
