#1 Posted : Monday, 11 June 2007 8:30:39 AM(UTC)
EB cranks but wont fire.
Had the cam bolt shear and the chain went forward and smashed the rocker cover and broke the exaust rocker arm on 5.
The bolt held the cog from falling down thank goodness.
Replaced the rocker assembly,rocker cover and used the tappets from the old arm to the new one.
Pulled off the timing cover and replaced the dampers as these had damage and realigned the coggs as they were thrown out due to the slip.
Replaced the head bolts etc and put back together.
Tried to start it.........it wants to fire,there is fuel being sent to the pistons and all seems ok but it is cranking but not firing.
Battery is on boost from the wall to give enough kick to start.
Put a timing light on and there is spark and the dizzy is correctly fitted and all wires and hoses are in place.
Did a self diog on the ecu and there is no fault code but a 52 being the power steering pressure switch which i already new about.
Any ideas??????????I am at a loss......
