hazzard county Offline
#1 Posted : Monday, 11 June 2007 1:12:32 PM(UTC)
hazzard county
anyone know if the hk monaro had engine lift brackets on the chevy engines from the factory as i have never seen one with these fitted were they on there then removed from the factory as the early corvettes & camaros had them maybe someone has some old pictures which they can check thanks
#2 Posted : Monday, 11 June 2007 5:54:19 PM(UTC)
These were removed normally in the factory, a small number of carsid leave the factory with them still on.
By your enquiry I suppose you found a set on ebay where the seller said they were mandatory. Well you do not need them if this is the case.
Wa
Sandman Offline
#3 Posted : Tuesday, 12 June 2007 9:33:19 AM(UTC)
Sandman
If you just want to use them pulling an engine out, don't worry.
I use a plate that bolts to the intake with the carb bolts. Works great, engine balances perfectly. And although theres probably people that will say that 4 x 5/16th bolts won't hold the w
#4 Posted : Tuesday, 12 June 2007 5:54:25 PM(UTC)
I hook into the rear of the rams horns with manual box for perfect balance.
Warren
#5 Posted : Thursday, 14 June 2007 6:09:12 AM(UTC)
hazzard county
reason i ask warren or anyone else that may know is that i have 2 what i think are original ones which were in a box with other engine parts which i what to leave on the motor i suppose as a factory extra now ones got 2 bolt holes & the other has one hol
