G'day to all,
I have a question I was asked today, and I don't know how to answer this one. Can anybody lend a hand. Can a WW Stromberg 186s Auto carby set up be fitted up to a 179 engine with a Hydra Matic???
Cheers james
1970 Green HT UTE... |
Thanks: 1 times Was thanked: 638 time(s) in 599 post(s)
Defintely. Will bolt straight on, and will be almost right tune wise. Make sure you use the cast headers as well.
Thankyou Byron, I will be sure to pass the info on.
Cheers james
I think the problem will only be linkages from carby to gearbox...if the current linkage doesn't fit I am sure it would be a very easy fix.
