Joined: 2/09/2015(UTC) Views messages in topic : 43,977
hi. just wondering what iginiton timing should be for a 302w. got a 650 holley, points dizzy but it does have a 351 cam in it. also i've adjusted the tappets but want to double check one of the rockers. does anyone know the clearances for inlet and exhaust valves?? ie. what size feeler gauge to use underneath the rocker? thanks guys.
I would not go by specs, windsors seem to run good at about 10-12 deg BTDC, don't run the vacuum advance eather. You want about 34-36 deg total advance when you rev your engine right up. You may need to get your dizzy re-graphed though. Do you have the st
