Hi people, do HJ control arms fit a HQ? I heard there is a difference but I thought they changed slightly from HZ on is this true?
Thanks in advance.
Matt.
Thanks: 1 times Was thanked: 638 time(s) in 599 post(s)
They'll fit. I think the only difference is the size of the hole in the bottom one so that bigger shocks can fit through. I don't think the part numbers changed either to recognise this change. If you ordered one in 1980 for a HQ you got a HZ one with the |
