#1 Posted : Friday, 20 April 2007 4:17:08 AM(UTC)
what is the easyest way to fit new mags on to my hj
peterwmh Offline
#2 Posted : Friday, 20 April 2007 5:25:08 AM(UTC)
peterwmh
The easiest way is to get secondhand HQ-WB Holden mags of course, Ebay is a good source or ask for some here. I'm pretty sure you can get them new still however, best to call Bob Jane or direct to a mag wheel manufacturer, eg Dragway, CSA etc.
#3 Posted : Friday, 20 April 2007 6:25:20 AM(UTC)
Do not put Commodore wheels on your HJ. They don't fit properly and are DANGEROUS.
You can also look for mags that suit the Chev Stud Pattern (5/4¾") which is the same as HQ - WB. Look through the US sites as they are still common over there.
Edited by user Friday, 20 April 2007 6:28:56 AM(UTC)  | Reason: Not specified
#4 Posted : Friday, 20 April 2007 7:17:41 AM(UTC)
i was looking at putting calais internationals on my HK premier , all that needs changing is the stub axles , which will inclube disc brakes so u might need new rotors and pads. the brake lines should be fine but you will need a brake booster.
as to
#5 Posted : Friday, 20 April 2007 8:06:57 AM(UTC)
There was a discussion on the topic of "Commodore rims on HQ-HZ Holdens" in the technical section a while ago...
DON'T DO IT..!!!
They do not fit properly. The stud pattern is slightly different (very slightly) and the studs BEND when you do them up
#6 Posted : Friday, 20 April 2007 10:27:59 AM(UTC)
As Luke said above, stud breakages are common when Commodore and HQ - WB wheels/hubs are mixed and not matched.
The other issue you will have with fitting Commodore wheels to an early Holden is the offset is VERY different and the wheels will sit "in"
#7 Posted : Monday, 23 April 2007 6:59:38 PM(UTC)
u can always get the wheel adaptors for them, i got mine through tempe tyres for about $200 for all 4.
#8 Posted : Monday, 23 April 2007 9:26:37 PM(UTC)
The only problem with that is wheel spacers are illegal and void your insurance...
Cheers...Dave
#9 Posted : Tuesday, 24 April 2007 2:16:48 AM(UTC)
how much dose that put your wheel out and can u then put all commodoor wheels on,and not have problems
