#1 Posted : Saturday, 28 April 2007 4:18:26 AM(UTC)
On a VS commodore...
ive replaces the door lock actuator... still no workies?!
ive checked all the fuses.... still no worky?!
symptoms:
you press lock on the key, EVERY door except the drivers door will lock....
yet... the driver button (when you push up and down manually) still makes the slaves (other door locks) go up and down... meaning the wiring is connected...
what could it be... anyone?
cheers!
#2 Posted : Saturday, 28 April 2007 6:03:03 AM(UTC)
I had the same problem it ended up being the BCM. I had a standard relay installed into the circuit to save me buying a BCM. Worked no worries
#3 Posted : Saturday, 28 April 2007 6:08:47 AM(UTC)
PanthaVS Offline
#4 Posted : Monday, 30 April 2007 4:56:34 AM(UTC)
PanthaVS
hmmm... any help here guys?!
Guest (5)
