BlaDe Offline
#1 Posted : Monday, 30 April 2007 3:47:43 AM(UTC)
BlaDe
Hi does anyone know where i could find some info on an efi v8 from a vr commo ie where all the sensors are located, oil pressure,temp sender oxygen sensors etc any help appreciated
Thanks BlaDe
BrianH Offline
#2 Posted : Monday, 30 April 2007 9:28:54 AM(UTC)
BrianH
If you actually have one of these engines and are serious about learning as much as possible about it then buy the genuine factory manual covering the engine. I have a VP V6 engine manual and it covers the entire mechanical side of it plus cooling, engin
Edited by user Monday, 30 April 2007 9:31:15 AM(UTC)  | Reason: Not specified
HZute-efi-VS5L Offline
#3 Posted : Monday, 30 April 2007 5:53:10 PM(UTC)
HZute-efi-VS5L
brian is right. i have a genuine vr v8 one and its damn thick. about 1" atleast. just on the engine nothing else.
jason
www.stickthisdecals.com.au
Holdenute Offline
#4 Posted : Monday, 30 April 2007 7:58:57 PM(UTC)
Holdenute
I'll third that. The genuine manual is invaluable. Has the error codes as well.
Never late in a V8
Never late in a V8
BlaDe Offline
#5 Posted : Tuesday, 1 May 2007 2:17:21 AM(UTC)
BlaDe
cheers thanks guys
Mr Void Offline
#6 Posted : Wednesday, 2 May 2007 8:32:34 PM(UTC)
Mr Void
Don't forget to check on ebay - you can pick factory manuals up on there for quiet reasonable prices most of the time.
...just make sure it's an original GMH part and not a gregories or similar!
___________________
Why are you reading this, you shoul
___________________
Guest (6)
