pdtphil Offline
#1 Posted : Wednesday, 2 May 2007 10:01:41 PM(UTC)
pdtphil
Hi all, Just wondering if anyone has the measurements for Headlight Alignment. I have fiddled around with my WB Caprice front end setup but cannot get the right set up. I've tried searching the net but there must be a simple diagram with the measurements from ground and left and right. I live in a bush area and adjusted them to the sides more to catch the Roos but this leaves little light for normal roads. I haven't been flashed yet but don't want to interfere with on coming traffic. I want to go back to original set up. Thanx
"If in doubt, Power out"
Tour Director Offline
#2 Posted : Wednesday, 2 May 2007 10:42:39 PM(UTC)
Tour Director
Once you have your front end suspension etc setup then you need to get the headlights properly aimed by an Auto Elec or contact Hella for a suitable person. The headlight aiming is critical in both high and low operations to ensure you can see without bli
#3 Posted : Thursday, 3 May 2007 12:10:56 AM(UTC)
While Tour Director is absolutely correct, the Chart and "Bush Mechanic" versions are:
Park car on a flat area with about 8 metres of flat area in front of the vehicle.
Find a large sheet of plywood or similar and mark a centre line on it. Put the b
Edited by user Thursday, 3 May 2007 12:14:28 AM(UTC)  | Reason: Not specified
pdtphil Offline
#4 Posted : Thursday, 3 May 2007 1:28:39 AM(UTC)
pdtphil
Thanx 'Tour' and 'Qute', it helps me out and will try these methods. Good goin' guys.
Cheers.
