I'm talking lights here. I got on to this site by accident last week and bought up: http://www.ledshoponline.com/The 6 LED 2x3 interior replace LDE light is is fantastic. THe HQ interior has given me the ****s for at least 20 yrs. Now it is great. I also bought 4 T10 dash bulbs to fit over the week end: http://www.ledshoponline...e_dashboard_bulb.htm#T10Guys the interior roof light replacement if awesome. I'll give some feedback on the T10 single LED next week, cheers, Scott
Ah yes - a point of great annoyance to me too.
I took off those thick blue covers and that helped a bit...these should be awesome.
Cheers John the Dim HQ Owner
LED's are great aren't they! Not that I have used this yet but jaycar also have an alternative for the interior light - its a kit that replaces the whole thing I think, just saw it a day or two ago... http://www.jaycar.com.au...ductView.asp?ID=ZD0485&C |
___________________ - HJ turbotonner looks and goes like a sneezing rhino on heat! - |
I have an interior mirror out of a Camaro in the Qute which has 2 map lights in the bottom of it. They also work as the interior light(s). Even with no globe in the original interior light (because it won't be there when I remove the roof), I can read a w
Hi all,
Fitted the LED T10 dask lights today, even washed the dask light covers, they were covered in dust. Check it out this evening and an awesome blue golw now exists across my dash. I can read the guages and it acutally looks pretty good.
So I w
I curse this every time I drive the HQ at night... So Scott, are the T10 LED bulbs simply a plug-in change over, or do you need to buy the sockets too, and do some re-wiring/re-mounting?
Jason.
Hi Guys.
Jason, which T10 dash globes did you use for you HQ instruments, the narrow angle, the wide angle or the 'Star'.
Dr Terry |
Sorry Terry, I should have been clearer. I haven't done any conversion yet, I curse the original dash bulbs for being so dim. (And I admit I haven't yet cleaned up the lense to see if that helps.)
When I had my overheating issue a few weeks ago (turn
Guys, The T10 dashlight was a straight swap for the original ones, they did seem slightly larger but fitted Ok with the original blue covers all cleaned up. Dr Terry I used the single white ones as per the link at the top of the post. I drove home tonigh
Well I've got some led's on the way to try out. But over the weekend I took off the dash light lenses and cleaned them up... couldn't believe the dust that had collected there. It's a heap better already, still using the original bulbs!
Also took to
hi y,all, i am a tadd confused by all this dash light talk??? do these bulbs,,kits,,fit straight into back of dash?? i have a holden vb euro dash? will these bulbs plug straight in ?? thanks
ptpro |
more than basketcase than a bear! DOH!!! |
