Hi guys, I guess this is a easy question for those in the know... One of my projects on the go at the moment is running a HZ RTS chassis. I am stripping another chassis which is not RTS. I know the difference is in the chassis rails, so can someone please tell me if the top and bottom arms and the steering arms are the same, I was gonna keep them for spares but pointless if they different aye
From memory the top arm changed in part # but the design didn't. The top and bottom control arms can stay and there was a change in the RTS draglink but a few people say they can't spot the difference.I think at the idle arm end the bend is slightly diff
I think the main difference is a slight change in the mounting location of the upper arm.
I believe the arms are all the same and just slightly relocated.
I know there are differences in the drag links also but don't know exactly what it is. Maybe
A RTS draglink is longer than a std draglink.From memory it is about 10 mm longer.
Hi Guys.
Most of you have mentioned the various differences but have got some of them out of context.
Holden improved the suspension & steering systems in the HQ-WB range in 3 steps, not 1.
The 1st change was the steering arm/ratio change in earl |
thanks for that guys... Looks like I'll keep the stuff for spares. thanks
Thanks: 1 times Was thanked: 638 time(s) in 599 post(s)
The biggest change I've seen in teh control arms is the holes were made bigger in the lower arms for bigger shocks to fit through. I havd NOS units here with HQ part numbers but they have the bigger holes - must have been a running change.
____________ |
