hey guys just wanted to know if a VR/VS engen & box will bolt straight up and WIRE up in a VP.
yes and no...
V6 or V8?
VR and VS have DIFFERENT "engines" ...
the VP and VR SHARE the same "engine" if its a V6...
V8's are the same from the VN right up to VS i believe (5.0 LTR)
but will only transplant if the donor car, and recieving V
Hi stuart, my brother inlaw and i did a full engine and box swap on a vr we put a vn motor and 5 speed into a vr not sure if ur just doing an auto swap or converting to manual but we did auto to manual swap we sat the cars side by side and most things wer |
IF YOU WANT MORE INCHES STROKE IT!!! |
sorry guys i forgot to say engen size and what box the donner is a VR v6 auto and going into a v6 auto VP
ENGINE!!!
it is spelt ENGINE!!!
other than that... yes... swap away! no probs... plug and play!
(gearbox im not sure, but should be ok... someone confirm?)
Engine only don't use the VR transmission it's electronic & VP weren't.
It ****s me to tears when the media & state politicians refer to the Feder |
Thanks: 1 times Was thanked: 638 time(s) in 599 post(s)
quote: Originally posted by chevman
Hi stuart, my brother inlaw and i did a full engine and box swap on a vr we put a vn motor |
