DIGGING THROUGH THE SHED & FOUND A SLAVE CYLINDER WITH THE HOLDEN NAME & PART #7409134 WOULD THIS BE FOR A HK T OR G BY ANY CHANCE ??
Thanks: 1 times Was thanked: 638 time(s) in 599 post(s)
Not a valid HK or HT part number.
Hi hazzard.
The slave cylinder with the casting number 7409134 was originally fiited to FE-FC-FB-EK Holdens and was also used in HR with the Opel 4-speed. It has a 1 3/16" bore size. Note that the casting number is not the actual part number, it's part |
thanks good stuff this is a top web site
CAN THIS BE RESLEEVED TO SUIT A SAGGY WITH V8 WOULD IT HAVE THE CORRECT BORE STROKE, MOUNT ANGLE, ETC AS ITS PROBABLY THE CLOSEST I'M GOING TO GET TO THE ORIGINAL UNLESS SOMEONE HAS ONE 4 SALE LET US KNOW
