landy351 Offline
#1 Posted : Tuesday, 19 June 2007 3:13:47 AM(UTC)
landy351
Started my dual fuel ED falcon this morning with no probs backed out the drive and drove about 10 metres then it back fired and stopped it dead it has destroyed the air box and cant see any other damage or hoses off. since the back fire it will not start or run on gas or petrol cranks over fine. does anybody have ideas what the problem could be.
Please help me.
Thanks Mike
#2 Posted : Tuesday, 19 June 2007 4:27:54 AM(UTC)
Had this with my eb.Check the forums.
Check the fuel supply!If this is fine and you are comfortable removing the head it could be bent valves,as this was my problem 5 of them.
My issue was the timing chain sliped off and caused the timing to slip and af
landy351 Offline
#3 Posted : Wednesday, 20 June 2007 3:15:45 AM(UTC)
landy351
After trialing several different possibilities it turns out that the ignition coil had failed causing the gas system to backfire which in turn blew the airbox in half as well as the vacuum line to the map sensor so even if it did spark again it wouldnt ha
This page was generated in 0.102 seconds.
