#1 Posted : Thursday, 10 May 2007 6:56:11 AM(UTC)
can anyone shed some light on a 308.......QT529547.....casting number D230. Came out of a HQ tonner, but not likely that it was originally in that. Is it 23 April 1970 or have I got this wrong?
boom Offline
#2 Posted : Thursday, 10 May 2007 7:51:32 AM(UTC)
boom
i think it was originally in an HJ, ask byron though if you want a specific date. Might be late HQ
Hyundai's are like rust. They keep coming back
#3 Posted : Thursday, 10 May 2007 9:30:01 AM(UTC)
The date code is 23/4/70 but the engine number is too late for that date code. It must have been restamped. QT529xxx is close to the end of HQ. The block is probably from a late HT or early HG. Most likely has 308 on the side but could possibly have HP.
Edited by user Thursday, 10 May 2007 9:38:38 AM(UTC)  | Reason: Not specified
#4 Posted : Thursday, 10 May 2007 5:13:25 PM(UTC)
Hi Guys.
A casting date of D236 would line up with the engine number. Could the last digit be a 6 not a zero ?
Dr Terry.
#5 Posted : Thursday, 10 May 2007 7:05:58 PM(UTC)
I don't think that's possible Terry as from memory Holden had switched away from US date codes by that stage. 23/4/76 should have 23D6. Plus by that stage engine numbers from my records are around Qx66xxxx.
_____________________________________________
#6 Posted : Friday, 11 May 2007 3:23:46 AM(UTC)
Thx Byron, Dr T. It has a 308 stamp on the side of the block. It's definitely a 0 on the casting number. What Byron's saying seems to be the most logical. Anyway, it works for me until I find my Jxx1 (sep 1971) date coded 308 block or QT engine ....so if
